76ford466
Another member
We'll since I can't leave things alone I tore my bottom end apart. I have a 7.3 1988 from f250 truck. Found the rings was wore past spec manual I have says 0.045 gap on top ring I had 0.075 and 0.085 on second ring. Pistons looked good. Bore has 0.006 taper from top to bottom and 0.002 egg shape but is within limits so I decided to resue the pistons not bore the block and rebearing it. Ordered king main and rod bearings. Std size. And perfect circle by mahle rings. 41548 part number says for 88-94 idi. But these rings are 3mm top 2mm second 3mm oil. My pistons are according to mahle who made them 5/64 5/64 7/64 rings. Mahle stopped making these 41547 part number, Hastings, sealed power, total seal all doesn't make a set to fit. They can come up with a top and second ring but no oil ring. International dealer says he can't look up ford engine stuff, ford place says it obsolete no old stock in the dealer net work. Anyone else run into this? Short of new pistons any suggestions? I did find a sealed power kit with a Molly faced top ring and cast second but oil ring is wrong that I could use but still no 4.110 7/64 oil rings I can find
