DieselCowboy
I have a 77 F150 that I've pretty much dumped my heart and soul into and it has done nothing but screw me. The oil pump went out and I blew up the 390 that I put in it last summer, and just got running fine a week and a half before it blew up. (I may have put 150 miles on it...)
I picked up an 89 7.3IDI with 110k, ZF5 2wd, tranny, wiring harness, hydraulic clutch set up, and motor mounts for $200. I was told it was for a mud truck project and that it runs good, but the guy had too many projects and he needed it gone.
My plan is to get the motor into the F150 with 5 inch turnouts, etc, etc.
But...
How hard is this going to be?
I have no problem with fabricating, but I'm lost. I know that the motor weighs on the up side of 900lbs. My plan was to just get lift springs, coil spacers, etc to compensate for the massive chunk of iron crushing my dinky coils. I'm doing a highboy frame swap in the near future, so this is just temporary.
With it being a half ton and the motor only being offered 3/4 and up, will the frame hold up to it? I have a feeling it will because the frame seems more "heavy duty" than the one on my 94 F150. Just curious.
The truck has a NP something or other 4spd. I know it wont bolt up and I don't like the way they're geared. I'm a poor kid so fuel economy is king so I'm going to stick with the ZF. What will I have to do to get this to fit? I'm guessing a new crossmember, but I'm lost after that.
What will I have to do to keep my 4x4? I was thinking about just getting a divorced tcase from a highboy, but I was told that you lose a good bit of torque because all of the driveshafts. My friend told me that I could swap out the tail shaft of the tranny with the tail shaft on the ZF bolted to my 302. Therefore the tcase from it would work, too. I'm not sure.
I'm relatively new to the diesel pickup scene. What should I know about these motors? I've been told they're really reliable and capable of 400k-500k miles. I know they don't have the power to set the world on fire, but I'm not worried about it. If you guys that are familiar with them could tell me the ups and downs of them, that'd be awesome.
Anything else I should know?
Thanks for your help!!!
But...
