7.3 turbo idi help
brandon
ohio
I have a 1994 7.3 turbo idi with the eo4d transmission and over drive light is flashing and all I'm getting is a code 94 don't have a clue to what it means
Hi welcome to OB,
Try searching that out here on the sight...search is in upper right corner, there are tons of threads on this issue. You should be able to find plenty to get you started.
Also look at FAQ start here and tech sections and hall of shame.
Again welcome to OB
Al
haubert
carlisle pa
Code 94 Torque converter solenoid circuit failure
Sent from my SCH-i705 using Tapatalk
brandon
ohio
The scanner brings up CCC/ss4 circuit fault/thermactor air inoperative
haubert
carlisle pa
Not sure, I looked it up on my code chart for my 93 thought it would be the same
brandon
ohio
I can't find anything and don't know if its going to hurt my transmission
