7.3 idi rough start white smoke puffing out between shifts
Matt0608
Alright so I’m just trying to figure out what my issue is considering the fact I’m a good ways from home. Some info on the truck before I get into the issues are, it’s a 4wd 93 7.3 idi n/a with an e4od trans. Extended cab long bed xlt. So the issue I’m having is that this morning when my father and I got out of the woods, we started up the truck to switch spots and the truck started up really rough, and puffing out some white smoke, and ran like that for about a minute or so. We go to pull out onto the road, and lay into the throttle cause it’s a 55 mph road, and it just puffs out a ton of white smoke between shifts. I’m not sure what it could be, I really appreciate it if someone out there has an idea of what’s wrong, Hope I explained it well enough for ya. Thanks in advanced
ABNORDY
Yuma
EGR cooler!
Sent from my SM-N950U using Tapatalk
ABNORDY
Yuma
Maybe one of your injectors is stuck and its unburned fuel also
RetiringColt
Washougal WA.
Did it quit smoking after it warmed up? If so I would suspect a failing glow plug. there pretty easy to check with a dvom or even a test light on the n/a engines. if one is bad I suggest replacing them all. everybody here recommends installing the factory ford glow plugs.
olsen726
