7.3 IDI parts. Complete engine tear down
ridgerunner
Upstate, SC
Finally got around to disassembling the 92 7.3 that I swapped out of the F350. I had suspected head gasket issues. Sure enough, bad head gasket on each side. I really hated to go any further, but, I have nothing to put it in.
So, I have all the engine parts for sale.
Good set of heads
Head bolts
Very good block
Crankshaft
Harmonic balancer
Camshaft with gear
8 good pistons & rods
Oil squirters at cylinder walls
Oil pan
Oil pump
Oil pickup tube / strainer
IP; sold
IP drive gear
Intake manifold
Exhaust manifolds
Valve covers
Water pump
Mechanical fuel pump
Power steering pump
Brackets on front of block for Serpentine belt
Heavy items will have to be local pick up only.
