7.3 idi no start when warm
Mtew2000
Parrish
Think Ip finally took a dump. How do I know if I’m getting a good pump from a good builder ?
Hydro-idi
Lodi, California
Buy an injection pump from Russ aka typ4, Mel aka Agnem @ Conestoga Diesel, or R & D idi performance.
If you buy a pump from anywhere else, you can expect it to be a POS.
Joseph Davis
Lompoc, CA
When it is time for mine, I am going to mini moose her because they will work right for a + 300 over the best deals on the internet. Check out their IP @ Conestoga Diesel Injection
Mtew2000
Parrish
Update in 94 f350 no start when warm. Got my moose pump and injectors installed. Runs great and starts right up when warm. Thanks conestoga diesel. Wish I would’ve found this site about 3 injector pumps ago.
Mtew2000
Parrish
Now for my next problem. Speedometer and odometer quit working. Any suggestions where to start?
DrCharles
West Plains, MO
Might want to start a new thread...
When you say "quit working", does that mean no digits showing on the odo at all, or is it displaying the miles but not advancing as you drive?
Mtew2000
Parrish
Nothing shows up at all and speedometer doesn’t work.
DrCharles
West Plains, MO
Do your dome lights work? Is fuse 8 ok (power to dome lights, cruise, radio memory and PSOM)? And fuse 18 (also PSOM power)?
Look at the last page of the attached wiring diagram. Hope that helps.
  • F250 instrument panel.pdf
Nick382
Ohio
VSS and pickup. One in the differential, other sensor on driver side of the transmission. If auto, check fuses under hood.
tke395
