42-50 mph shaking vibrating
gcf330
X
Greensboro GA
I definitely feel it in the steering. I am going to get the tires balanced again then I will check bushings and other suspension and steering parts.
grog85
novi,mi
I've had loose tie-rod ends cause exactly what you're describing, you might check them out.
Titojeep
Dacula, Ga
My shake was due to the I beam mounts being cracked. Jack up the front and pull ******* the top and bottom of tire while someone watches the brackets and bushings. Oil leak from valve covers will tend to drip right on the bushing in the middle thus causing it to harden up.
