2001 Ford F-250 7.3 diesel transmission problems.
diesel fumes
hatley wi
had same issue with 97 f350 7.3 e4od some years back. blew out a few quarts throug seal after hauling load for couple hours on highway. had it towed home. did not pull trans or replace seal. replaced stock tiny oil cooler with 6.0 cooler ;larger iles; remote oil trans spinon filter ; larger oil pan with cooling tubes;and trans temp gauge; no problems since ; oil temp never gets above 140
Skidtech
Idaho
I usually just bypass the tranny cooler in the radiator with an aftermarket super cooler but ive never tried a 6.0 cooler. That's a good idea.
Sent from my LG-H700 using Tapatalk
DieselDc
Safety Harbor
I have both a 6.0 and a trucool 40k cooler on my trucks and both are the same with the exception the trucool keeps my Transmission a little cooler.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
Schluchtenflitzer
Germany
Out of curios. Why changing the tranny? If it gets to hot while towing it could a lot of reasons but why should the tranny be weak?
