Been browsing the site for a while now, trying to diagnose a problem with this truck. I'm not sure where to start explaining the previous owners wiring.
When I got it, it had a push button start as it wouldn't start with the key, power to the cab, all lights work, etc, but no crank. The push button start is an extension cord jumping the solenoid to a button in the cab, awesome...
Glow plugs were not functioning, they are brand new, along with a new oem starter. The original gpc was not fiddled with, and the po suspected either a gpr or the controller so I went ahead and bypassed the gpc (following the guide on this site) and replaced the relay because I am a cheap ******* and in the middle of nowhere.
Some numbers:
11.7v on the S & I terminals on the GPR KEY ON
12.2v on the hot side of the GPR KEY ON
I don't have anyone around right now to help me test the GP voltage.
Do these numbers seem low? I am thinking the problem lies somewhere between the GPR and ignition switch or from GPR to the glow plugs themselves. There were two grounds that were not connected (one on the starter solenoid and one from under the GPC somewhere to the hood of the truck. I hooked them up, no change.
The batteries are also brand new, but the cables are quite shabby.
Starts fine on ether.
Any advise on troubleshooting from here?
Glow plugs were not functioning, they are brand new, along with a new oem starter. The original gpc was not fiddled with, and the po suspected either a gpr or the controller so I went ahead and bypassed the gpc (following the guide on this site) and replaced the relay because I am a cheap ******* and in the middle of nowhere.Some numbers:
