1990 Ford F 350 Super Cab Truck
cbwells
Lewiston Michigan usa
Truck will set and run but as soon as I start down the road it stops no fuel, I check the fuel filter and it is half full usually full right to the top. Took the line off the exit side of the filter no fuel comes out. Is it the fuel pump? Thanks Curt
riphip
Memphis, TN.
Could be or sucking air. If you use an electric pump, it will be easier to make sure fuel is getting to the filter.
Just a suggestion, won't have to run engine to check.
chillman88
Central NY
How much fuel is in the tanks? You're definitely sucking air if the filter is only half full.
Alleycat
