Jan 31, 2008 #1 dairieman36 Full Access Member Joined Dec 20, 2007 Posts 318 Reaction score 0 Location st.joe MO well thought i had a d60 but the insides were completely messed up.. can i use the drivers side beam off of a 1/2 ton 44 and put it on my 50?
Jan 31, 2008 #2 suv7734 Registered User Joined Jan 8, 2005 Posts 974 Reaction score 1 Location BC Canada I believe you said it was the left side that was bent and the left side 'beams' are the same. scroll down this page a bit Last edited: Jan 31, 2008
Jan 31, 2008 #3 dairieman36 Full Access Member Joined Dec 20, 2007 Posts 318 Reaction score 0 Location st.joe MO ok i thought that could be done just wanted to make sure before i bought any parts ... thanks a lot
Jan 31, 2008 #4 towcat Supporting Member Supporting Member Joined Jun 24, 2004 Posts 18,196 Reaction score 1,439 Location SantaClara,Ca/Hamilton,TX iirc the 1/2 ton d44 is a coil spring setup. the 3/4t d50 is a leaf spring setup. you're going to have fun moving around the mountings.
Jan 31, 2008 #5 82F100SWB Full Access Member Joined Oct 16, 2005 Posts 1,187 Reaction score 1 Location Sioux Lookout, Ontario,CA You need a DS beam from a D50, ball joint spacing is different with either D44.
