94 F250 IDI turbo 4x4
NJGearhead666
New Jersey
Figured I'd give you guys here a shot at her since most of you have the ability and time to fix her if you want a project. If not they I will part her out and give this site first crack at parts.
I just don't have time for her anymore, Bought a new truck awhile ago and as much as I want to keep her I just can't. Its the truck in my sig, was in an accident but after checking over the frame it suffered no damage. needs a rad support, radiator and all forward sheet metal. cab shifted and has typical N.J. rust so a new cab would be best. Bed has no rust but a dent on the back passenger side from being towed an the driver clearly rubbing it on something in the tow yard. Also needs a driver side F350 spring since it got damaged.
Truck only has 90k miles on it. Factory Turbo, does not smoke. Only modification has been a banks down pipe. Transmission was rebuilt at about 57000 miles by Fisher Transmission here in NJ with all the updates and a magtech trans pan. (I can find all the paperwork) D60 front end installed 3years ago with new ball joints and have all new moog steering components still in the boxes to replace damaged ones.
Weall know what the parts go for but if someone wants the whole truck we can always work something out. If no interest in whole truck then a full part out.
Truck is located in Garfield N.J.
NJGearhead666
New Jersey
HS108
Diesel Newb
Connecticut
How are window visors attached? Do you have the covers for the OBD1 sensors? Or does the glow plug controller have a black plastic cover?
NJGearhead666
New Jersey
Window visors just snap in if I remember. Been on the truck since 2000 so I really don't remember lol I do have the OBD1 cover but do not have the injector pump
HS108
Diesel Newb
Connecticut
Ok get me a priced shipped to 06118 for the visors and the covers for the OBD1 plugs, IDK how but i lost/broke mine lol
Also maybe the GP controller as well. I could use a back up one
I cant see the attachment, but i trust we are on the same page
NJGearhead666
New Jersey
Here is the cover for the obd ports. I'll pull the window guards off on Friday when I'm off work and the glowplug relay and see what size box they will fit in
bad67ford
nj
Hi I’m interested in the engine, turbo, and transmission pm me with some prices
Thanks
Lance
