For years I understood how our indirect injection worked, but there is nothing like seeing it for yourself. I know there are a lot of guys on here that have never even taken the head off one of these engines.
I had a set of heads(no good cracked junk btw) that I am going to strip down all the parts and hang on to them. I decided to take some pictures during disassembly and post them up.
Combustion side of the head. Valves and pre-cup opening visible.
Now the pre-cup is out. The glow plug is clearly visible sticking out into th combustion area and the injector nozzle can be seen all the way down in the bottom.
Backside of the cup.
And now, the combustion area its the glow plug and injector removed. You can see light through the injector hole.
By the way. This engine has all the classic symptoms of over fueling. There are cracks between the valve in the heads, the throats of the pre-cups are cracked, and the Pistons have cracks on the tops of them. This is what happens when you max out you IP and roal coal like a fool. Anybody think it's cool now?
How do you get pre cups out?
