Possibly cavitated engine?
habaneropep2019
Iowa, United States
Dug deeper into my troubled engine (low compression on #4 and #6, 100-150 psi lower than other cylinders). Pulled the valve cover off and was greeted with this lovely sludge mess.
Did a leakage test and determined it is primarily leaking past the intake valves, though there is some small leakage past the exhaust on one cylinder. No pressure in cooling system at TDC on either suspect cylinder.
Then I dropped cylinders to BDC and loosened the rockers so valves would stay shut. Applied shop air, and lo and behold cylinder number #4 pressurized the cooling system.
While I know the valves leaking is definitely the cause of low compression, I’m worried that the cooling system pressurizing on the bottom of the stroke is indicating cavitation on that cylinder. If it was a blown head gasket I would expect it to pressurize at TDC as well, and that did not seem to be the case. The engine was low on coolant when I got it with no external leaks that I could find when warmed up, so I suspect coolant has gone somewhere internally.
Thoughts?
ihc1470
Idaho
Pull the oil drain plug and see what comes out. You can unthread it and hold it against the pan. You should not loose that much oil and water will come out first if there.
habaneropep2019
Iowa, United States
When I changed the oil it was overfull by a decent amount. There wasn’t water at the bottom but it may have been mixed in from running. I don’t think it had fuel in the oil, I know the smell of that.
ihc1470
Idaho
Let is sit for a few days and crack the plug again and see what you find. This is if you have the coolant full.
Olds64
Edmond, OK
You mentioned that the oil was over full. Did you recently pull the engine, had it been running with low compression? If you've been running it recently with a mechanical fuel pump be aware that the OE style mechanical fuel pumps have been known to pump diesel into the crankcase.
Oiler
