Does the way this previous owner hooked up the boost gauge work?
headhunter38
California
The red highlighted line is connected to the boost gauge that the previous owner installed. Is this a viable way to do it? Im not getting any movement on the gauge. I have read about the circled in blue pipe plug on the intake snail. Should I switch it to that spot? 1994 factory turbo f350.
Clb
Another old truck
nannyfornia
Pretty much the same, ugly? Perhaps.
The gauge is suspect, try feeding it regulated psi, 5-10psi observe the gauge.
They tapped it into the wastegate line. Yes it would work, but yeah, ugly. I put mine on the port you highlighted blue. Sounds like your gauge is a dud
Oiler
