ZF5 s42
MUDKICKR
NITRO WV 25143
if your running a dana 50 frt axle and a 10.25 rear axle i could hook you up with some 4.56 gears.
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
I really want a ZF5 s47 but all i keep finding are s42-cuss.Trying to make something work with what i got. Getting closer to doing my engine swap
I wish I had that problem around here! All I found was a 47......for $1400.
Send some of them spares up this way!!!
I remember at Ace towing we had a 1996 PSD truck. The case got broken when a driver decided to hop up and over a rock that he shouldn't have been anywheres near.
The boss sent another truck to bring it back in, fired the driver, had me pull the transmission and had his mechanic Terry do what you said.
He had an old S5-42 from an IDI flatbed that had long since bit the dust, but there was metal shavings in the case. So the 47 guts went into the 42 case (or that's what I remember on my last going off while working on that truck)
The next day that truck was back in service with the 42 case in her.
Get a parts diagram of the 42 and the 47 and compare. I think it should be ok.
MidnightBlade
Shiftin' Smooth
Johnstown, PA
my stock zf5 with 4.10's or 4.11's tops out at 5 mph in first. but then again my top speed is 70 i think, 65mph @ 2000rpm
hce
So can i....
Glasgow MT (Official middle of nowhere)
The 38 and 4.11 will give just a little taller ratio then my 3.55 with 32". I have no problem with the 4.14 first actually think it is more usable then the 5.11 the t-19 had. Also the 3 to 4 jump was to wide with the t-19 when towing.
rjjp
Needs to go test
Clare, Mi
You're top speed (governed) will be over 100, but that's just about right for a stock tire, with a 32" tire, 4.10 gears and OD you should be at 64 at 2000 RPM so I'd say you're speedo is good.
bigrandy
carson wa
I dont really remember the numbers,but I had the guts from an 87 with a 460 put into a diesel case that I got from a tranny shop.He said it was from an 88,it only took him a couple hours.he said it was a simple swap.I just dont know what trannies were available when.:dunno Hope this helps
Diesel_brad
Dunce
gilbert pa
Thanks! That is the answer i was looking for. the s42 started in 87 was available till mid 95 then the s47 took its place and ran till 99
dyoung14
Is getting worn out
spencer,tn
I dont thin the 3-4 is that bad on th T-19, the 2-3 shift is what really kills ya when towing heavy or it does me, i would love to have a ZF5 there just all around great transmissions
SixFourShanks08
Staff online
