zf 5 swap
performancelaw
Auburndale FL
I'm going to be doing the zf 5 swap in the next two weeks and getting rid of the junk e4od. I'm buying everything I think I need from someone. Just to be sure I get everything I need and don't have to make an unneeded 3.5 hour drive to get more parts from him. Can someone that has done the swap give me a complete list of what ill need. Also how hard it is to put the new pedal in etc .....
Thanks
Tex_50613
Waterloo, IA
I can tell ya what all you need but don't know about the pedal cause I'm putting mine in a Chevy,
what you need from the doner truck,
the trans, the clutch pedal assembly, clutch master cylinder, clutch slave cylinder, the line between the master and slave, flywheel (I recommend having it re-surfaced), pressure plate (have it checked and re-surfaced), clutch disk (s), throwout bearing, possibly the trans cross member and drive shaft (s) but this I'm not sure about being as I'm putting mine in a 85 chevy and using a divorced np-205
snaponprofile
NY
Yes, driveshafts and crossmember. You can't use pedals from a 83-91 truck, they must be OBS.
Vinceslamer
