Weird issue with timing my bull moose
BDCarrillo
Abilene TX
Intermittent wire connection (not ground, per Laserjock below) on pyro?
Ford rotary resistors for dimmer control are notorious for crapping out from carbon buildup on the spring. Jumpered it on my 'stang.
Glad you got your truck out from being retarded
THANK YOU EVERYONE!
shes not retarded anymore, thats for sure!
ill look at the pyro tomorrow. dark, tired, and yet another headache....
good night folks!
bbjordan
Snow Monkey
Ashern Manitoba
Way to go BDCarillo! :hail
I knew it would only be a matter of time before the collective figured it out. :)
As pointed out tho, the timing is still out about 18 degrees. That is about 2 teeth out! Each tooth is about 6.8 degrees. It might be easier just to advance the timing gear 2 teeth. :dunno
Wow, I can hardly believe it ran that retarded. You will really be in for a treat when it gets timed up right.
laserjock
Almost there...
Pyro is typically type k thermocouple. While it does have a +\-, there is no ground per se. Probably a loose wire. Should be yellow and red wire. Ironically the red wire is the negative. And it's special wire so of its broke, you shouldn't just put copper in its place. It won't read exactly right.
Clb
Another old truck
nannyfornia
No cell service on the lake today, I will call ya later.
2 teeth sounds familiar,,, nice ya got 1/2" rotation?!
Ok the boats a calling to go for a ride!
marmot
On the bench
Twin Bridges, MT
Went fishing with the kids yesterday, Ice chunks floating in the water, got SKUNKED. But we had a blast;Sweet Glad you got it sorta figured out man... NOw go rip some lip. You guys are making me jealous.
Clb
Another old truck
nannyfornia
The function of how he adjusts the pump, being top of pump pushed to drivers side to advance vs top towards passengers is the only issue here.
Edit cb^^^^ this is my issue
You sure you weren't reading BTDC and ATDC backwards?
Having it at 7 ATDC and going toward the passenger side would decrease the number, as you observed... then going towards drivers side to 9 ATDC you observed it to be sluggish... which fits for retarded timing and normal operationwro
Edit cb yep that makes sense,,, cept I did not see any minus sign going driver.
wow.... now this is the first thing ive heard that opened my eyes wide open....
https://www.youtube.com/watch?v=Za5sKp04btg&list=UUeOaJTOsAypB8fJnjLCWSkQ
^^^^ this was not my meter.
Brian monday work for you? Got comitments tomorrow. What ever went south ???dunno! What ever has been redone 'I will get over there and run the meter on it again to put it in time .now to drive my sorry *** back down the mountain. Fed the lunkers and their offspring. But still a good day. Later cb
im on your schedule brother.
shes rattling on cold idle like i got it dead nuts!!!
im going to guess 9.5 ADVANCED LOL
i have the cash burnin a hole in my pocket ;Sweet
ill be doing my normal 5-5 monday.
charge your phone and give me a shout.
i just ripped her in the field, and OMG.
im pretty stoked.
this was Garys meter.
update:
CLB just came over to time my truck again.
we could only get it to 2*ish
but its on the positive side again!
I HAVE to be a tooth off......
ironworker40
NYC Ironworker
nj
Were is the index mark? Are you all they way counterclockwise in the slots? or are the lines holding you back?
marmot
On the bench
Twin Bridges, MT
Damn sorry to hear that but Luckily these trucks are easy as pie to wrench on. So no big deal there. I bet it runs better at +2 than it did at-9 tho.:D
MUCH MUCH BETTER!
yes, i am at the end of the slots.
im not gonna mess with it until my turbo gets here.
the core goes out tomorrow!!! (dances a jig)
THANK YOU TOUGHOLDFORD!
ill run it as easy as i can until then.
ill update when its done!
rhill5353
