Weather stripping on rear slider?
Danielle
No, it's not finished
Dirty Jersey
Is there a source or another product you can use? For the rear slider glass. My kids keep making fun of me
gandalf
Senior Member
CA &/or Maine
Are the girls making fun of you or of your truck? You realize, don't you, that it's a girl's right to make fun of her mother.
We need a picture of this weatherstripping.
MommaHobbit
The Shire
Where you able to find one? I'm trying to find the same thing. Ive got some duct tape on mine lol.
Duct Tape? Iam using Gorilla tape, the manly stuff...LOL
I have had it on all winter, around the whole window.
I knew there was some rust under the corners of the window on the out side. Wasn`t till I removed the whole interior to Dynamat everything i discovered the sheet metal on the inside corners were totally gone 3" each side and about 2" wide at the widest.
If I had not removed the plastic panels would have never seen it.
Iam wondering if this is the big cause of the cab Corners rusting out? Water leaks between the pinch weld, and leaks between the inside and out side sheet metal panels.
My 86 is too far gone to worry about it now, looking for a good rust free cab to sand blast and redo.
Are you looking for the rubber that holds the window in or the seals on the window glass itself? I bought the seal that holds the window in from LMC. Might try a thin foam tape on the joint where the slider goes if that’s what you are looking for.
