hotford
Well, a while back I was on here with some problems with my truck. Figured it was head gaskets. Tore into it and the gaskets, rockers, lifters, rods, where toast. So I got new heads, rockers, lifters, rods, gaskets. Dude was going back together and then he saw that the lifter stuck and wore out the cam in spots. So out came the motor and got into her more. Looks like someone has replaced the crank at some point. Once in there we saw 3 missing piston cooling jets in the pan and spot in one of the cylinder walls. The spot in small and not to deep. You can feel it and see it once the piston is swept across it. I found a new cam for $100.
Now what to do? Should I stone the walls, through new bearing at it and hope for the best or look for another motor. The block only has 180k on it. I'm not looking to build a pulling sled. I just need this truck to yank around my 6k Jeep and be reliable. I got the truck for $2500 and now I have about $1500 in a head gasket job. I don't want this to turn into a money pit and through a load of money at that is not needed.
With this spot in the cylinder wall, do I risk melting down a piston soon. Or will it heat up and swell and never know it.
Thanks for the help.
Chris
Chris
