Turning up fuel
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
i sealed up where the turbo goes into the snail. how can i test for a leaking snail? could i take a bottle of soapy water and spray where the snail meets the mani and look for bubbles? i still have the old boost gauge. i will a/c test that.
Ididriver
Panama city beach
The water trick is worth a shot.
Have you tried just tightening down the watergate rod yet?
Really seems like it's just bleeding off pressure
gsxjay
ashland ohio
when i did mine my max boost is 10 psi and i can hit 1200 very quick from when i stop at a light il punch it and at about 75 8o mph i am right at 1200 so i back off
'94IDITurbo7.3
HAMMER DOWN!
i tested my other boost gauge and got the same results. so nothing is wrong with my glow shift gauge or the tubing. i tried the water around the intake but that did nothing.
'94IDITurbo7.3
HAMMER DOWN!
i found this when looking at my snail.
i am wondering if when i reach 5psi the o-ring kind of blows out creating a wastegate effect and dumping boost.
rhkcommander
Oregon
very possibly. If you've got a digi cam, mount it in there + light and put some suds there and go for a spin. record and see if you blow bubbles. My .02$ and guessing
That gasket in the picture is not leaking. If it was there would be oil around the leak. Remember the crd blows into the intake and mixes with the air charge.
Ididriver
Panama city beach
I still think wastegate is letting boost bleed off.
How bad is your airfilter? I know those stock intakes suck and a dirty airfilter woe just back it suck even more.
'94IDITurbo7.3
HAMMER DOWN!
i am pretty sure i figured it out.
i decided to take my wg off and adjust it. well before i changed it's setting i figured i would test it out to see when it opens. so i rigged up my a/c and tested it. i could hear a hissing coming from the wg actuator. turns out there is a tiny hole in it that was bleeding off air.
i will upload a pic in a few minutes.
'94IDITurbo7.3
HAMMER DOWN!
here is the hole. it is a lot smaller in person than in the pic.
suggestions on fixing it? i was thinking clean the metal up and some JB weld.
ntjapkes
