'94IDITurbo7.3
HAMMER DOWN!
i don't see why jb wouldn't work. the actuator is not under any twisting stress or anything like that.
Not knowing how the 90 connects to the turbo outlet.
Can you just put a bolt in there and see what you get?
Is it possible that your muffler could be clogged? Or a restriction on the exhaust side of the turbo?
Your turbo might need some love. I put a Uhaul pump on my pickup last summer and turned up the pump as much as she'd go (then backed it off a flat) It was a smoky pig and it didn't really increase my boost that much. (and my timing was in pretty good shape) Well turns out the turbine wheel was in pretty **** pour shape. Typ4 has pics of it somewhere around here. I hadn't owned the pickup very long when this all happened, so I'm sure the Prior Owner pulled her heavy and got it warm. After a turbo rebuild, she's been building boost with the best of em
that has entered my mind.
plugging wg=no increase in boost, sealing up-pipe leak = no boost increase, turning up fuel about .5-1 flat = no boost increase. all of which should have given me more boost but did not.
i also have ZERO hotside whistle.
How long after you shut the engine off does the comp wheel continue to spin? mine stops almost right away.
