You didn't leave the the opening from the compressor to the hose open? The bolt still in the hose and sealing well? You're leaking boost pressure from some where.
Heath
Heath
Another thig I thought off. Don't you have a cowl induction setup and only getting 5 pounds?
yes, you think i might not be getting enough air?
air filter would be clogged then, that turbo will pull the air, leaves , dirt, and all, you need to go through and pressure check the pressure side piping including your gauge and the line leading to your gauge, put an air reg on your air line and hook it to the pressure side piping and see if the gauge corresponds to the pressure you are regulated to
yes put a regulator on your compressor
