Popeye2347
Due to the slick, snow covered roads I took my IDI 4x4 to work today and will for the next few days. On the way home I realized I have not read anything about engaging or driving with 4 HI engaged.
Two questions came to mind. First, what is the maximum speed you can engage 4 HI without damage.
Second, can one drive 45-50 mph in 4 HI without damaging the transfer case [or something else]? This assumes a slick driving surface. A slick surface is defined as one where the rear tires break traction easily when the accelerator pedal is floored at the target speed. [I know a dry surface will cause torque 'lock' problems and damage.]
FWIW I was proud of her, just let the GP's heat and then waited for a count of 10, and she started right up-Had to push the acc. pedal about 1/2 way, but first try and she was running. All after sitting outside, not plugged in, in 16*F for 8 hours. She also started last night in +8F, again without block heat.
Be safe, plan for a breakdown, have cold weather survival gear in you transportation, don't forget munchies and a working flashlight. A cell phone is nice too.
