Trans cooler
First tell the forum what your plans are for this rig. It helps to know if and what weight you might be planning on towing.
Ole BlackBetty
Norman, Oklahoma
I have a 12 ft 6 inch overhead camper weighs over 2500 lbs and a 24 ft sun tracker pontoon boat that it hauls. Went on a 110 mile trip from the house this last week to the lake and my tranny got hot and probably cooked it going down interstate #40 . After setting for a day the truck still drives but I'm sure the tranny is not to be trusted
Sent from my SAMSUNG-SM-N910A using Tapatalk
jayro88
Auburn IN
If you are planning on doing a bit of heavy towing and want something that is going to really shed some heat use one from a 6.0L. RockAuto has them here http://www.rockauto.com/catalog/moreinfo.php?pk=4980420&cc=1433536&jnid=524&jpid=15
That is what I put on my van along with a oil thermostat to keep from over cooling in the winter.
trackspeeder
Stone crusher.
North Branford. CT
6.0 cooler would be the best option. Runner up would be TruCool Max LPD 47391 by Long. The maker of Ford's tranny coolers.
gandalf
Senior Member
CA &/or Maine
I also run the TruCool Max.
I'm not sure I've ever seen an actual, factual, comparison between the TruCool Max and the Ford 6.0 cooler. That would be interesting.
Ole BlackBetty
Norman, Oklahoma
Thank you all for the replies, I just placed an order through amazon for a Tru cool max lpd 4739 cooler, a b&m remote filter system and a max tow transmission temperature gauge. Now to hope my tranny isn't already ruined.
chris142
SoCal
I pulled factory trans cooler off a truck in the junk yard to use as a PS cooler. It's mounted but not hooked up.... For like 2 yrs now lol
reset2
Myersville MD USA
I have read about but have not installed a cooler in my truck using the water radiator"s stock oil cooler as a secondary cooler. The only addition will be a tee and valve in the lines to bypass the water radiator cooler in the summer.
FORDF250HDXLT
Maine & Oklahoma
you want to keep the radiator as your primary cooler.especially in the summer.it's cooling abilities far surpass your aux cooler (second in line,air cooler.)
at no time does the radiator warm the atf.
typ4
Newberg,OR
What he said .^^^^^^^. the radiator pulls the high heat much quicker. , now if you have a plugged radiator cooler you need to upsize the air to oil cooler 2 sizes.
Knuckledragger
Payson, AZ
Another thing to do that will help keep trans temps down is add a deep oil pan. Adding 2 quarts to the mix will go a very long way to keep you temps under control, and the cast pans will act as a heat sink, doing a little cooling of their own.
trackspeeder
Stone crusher.
North Branford. CT
The only thing a deeper pan does is cool your wallet of $$$.
If want to add more fluid to cool, use a bigger cooler.
Where the tranny pan is located it doesn't have a direct cool air path. What air it get is usually heated by the engine and road surface.
