ticking noise!
blakken
sweden
can an injector sound more when the engine get warm?
Skickat från min iPhone med Tapatalk
Hydro-idi
Lodi, California
Mine did. Engine would not make ticking noise until engine was completely warmed up. Took me forever to figure out it was an injector making that noise. Somewhat unusual for an injector to do that IMO. Took truck to 3 shops and they were all stumped. They all thought it was an internal engine noise and wanted to tear it apart. Came close to taking engine out and digging into it when my bro helped me find the prob.
So you don't hear the noise coming from any of the rockers when engine is running?
http://www.oilburners.net/forums/showthread.php?75527-Fresh-Reman-Engine-Ticking/page15
blakken
sweden
i dint se any thing wrong with the rockers when i changed the lifters and poshrods!
today i was att the shop with the oem injectors for rebuilt. mabe its get better!
i bougth mine injector new from pensacola diesel and when they arrived they was in an market plastic bags. if it was new delfi injectors i think it should be marked pakage?
blakken
sweden
i have read the hole tred....thats wy i will reman the old
rustygold
conway Arkansas
Sometimes ticks can came from injector pump off time little bit. I had mine ticking to moved the injector pump started to sound better and no more ticking. I still need to get my correctly in time but been way to busy to do so
Sent from my SAMSUNG-SM-G870A using Tapatalk
Hydro-idi
Lodi, California
You can also try filling a fresh fuel filter with seafoam or atf, let run for a minute than shutoff, letting sit overnight. Then run it hard the next day. Always worth a try.
blakken
sweden
hmm
its little cold for that maby!
- 15 celsius
blakken
sweden
today it sounded on cold start and smothed out when warm. i think its ticking less when i hit the gaspedal and engine had to work hard
rustygold
conway Arkansas
I listened to mine it's does the same thing just little in cold cold mornings after it warmed up to 180 went away
It is a diesel truck therefore it is a throttle pedal ;Poke :rotflmao
blakken
sweden
haha[emoji849] you just get me ther[emoji23]
throttle pedal[emoji106]
blakken
sweden
whats the symptoms off injectors dont pop att same pressure?
blakken
sweden
ok! thats is what it does. i vill have them pop tested[emoji106]
