Dsl_Dog_Treat
I'm not taking that bet Russ Cuz I know he can do it!!!
Even today Gary, she told me to buy THIS TRUCK...... if I sell the '86 crew cab. I said it's nice, but I'll keep my IDI crew cab.
Heath
Yeah, there was no way in the world I was going to let him do that. But, it was "cheaper" to do it that way because he wouldn't have to keep taking the flywheel off the crank to mod and test it. Like you said, when it's time to change the flywheel it'd never be balanced.No way would I allow some balancer take off from the crank to make a flywheel balance out.. What will happen when you wear out the clutch and maybe burn up the wheel. Nothing else will ever balance that engine again. You were wise telling them not to cut that 300 gms off the crank. Thats about 10.6 ozs...
I doubt he put the pressure plate and disk on the flywheel during the balancing. But, those parts are South Bend's. The flywheel is not.Did you have the shop do a comparison with and without the clutch disk and pressure plate? I am wondering if Southbend is importing a poor quality flywheel and if their in house built clutch and pressure plate missed the balance issues at hand. Either way, a disappointment for such a highly regarded name in our industry.
Yup, like stated above, I'd be crazy to let them take the weight off the crank just to save the extra labor charge. I've been thinking about this for the last day or so and I remember a conversation with South Bend Clutch before I ordered the SMF kit. They said these IDI were externally ballanced. I told them that was not correct, they are internally balanced. I wonder if the flywheel they use is wrong based on that wrong assumption?They should have the capability of spinning the flywheel by itself, and verifying that it is neutrally balanced. This is how it should be done to a internally balanced rotating assembly. If they took weight off of the crank to compensate for the out of whack flywheel, what would happen if you ever had to change the flywheel?
300 grams off of the counterweight is ALOT
They would be way better off taking it off of the flywheel anyway; the further from the crank center line, the less weight needs to be removed. Same concept as leverage.
Talking with the balancer yesterday, he said he had no problems getting the pistons or rods to the same weight. I was glad to hear that as I remember you having an issue with some of your pistons being quite different in mass.When I was having difficultys with my Mahle pistons being so far off from the set of 8 I talked to the head inginers named Eric at Mahle in Tenn. He told be because we run at so low an rpm they felt that anything 14 grams differance in pistons and rotating weight was not going to be a problem
likely after the Holiday.
Heath
Don't make us wait that long!
