GREASE FIRE
last year i had the transfer case rebuilt on my truck...mechanic called just before i was going to pick it up and said there was leak so he was going to re-seal the cover plate...so he did that and i picked it up and it seemed fine but then i realized it was still leaking.
it seems that he cracked the case right near the drain plug when putting it back in because that is where it leaks. I have no idea if the crack had already been there before but i know it was not leaking there before.
anyway, it seems too late to complain so it looks like i will need to pull the cover plate. Next door neighbor is a pro welder & does aluminum so he will fix it for little more than a handshake.
question: does anyone know what size torx wrench is needed to pull the cover?
any tips would be greatly appreciated on how to do this. Does the extension on the TC cover that connects to the driveshaft (the thing that also has torx nuts) also have to come off? or just drop the entire driveshaft?
thanks!
Paul
thanks!
Paul
