austin92
So I decided to change my plans on a tach from the autometer alt. pick up and 2 5/8 gauge to a stock dash cluster that has a tach in it. Thanks to stealth13777 and langevette I have the cluster and gear cover with a tach pick up.
Now I’ve done a lot of reading on this install but I still have a few unanswered questions. One is swapping the timing cover and 2 is, I don’t think my harness has the plug for a tach.
Is there a way to remove the cover with out disturbing the timing gears? Gears are all the same whether the truck had a factory tach or not, correct?
Since I don’t think the plug is there for the tach pick up will the plug in the back of the cluster have leads coming out for the grounds, signal, and power? Is the power, constant or keyed?
Also, since I’m already going to be in there are there any recommended LED’s that won’t completely ruin the factory look? I don’t want to be blinded by my dash lol
1983 f350 6.9 zf5
1983 f350 6.9 zf5
