After getting more of the pieces put together I ran into some clearance problems with the hood. I am not sure anyone has done this conversion on my body style. Shimming the radiator forward about an inch caused the cap to interfere with the hood. To fix this I trimmed out a section with the plasma cutter.
I turned it down and tried to be quick but I still caused a blister on the top of the hood. Not a huge deal for me since when the hood was replaced from an accident they gave me one with rust running the whole inner seam.........
I also could not clear the battery cable running on top of the core support anymore either. Even when I stripped off the outer sheath it still would not clear.
So I came up with another solution. I took advantage of the bolts already existing on the radiator.
Now the cable is running through the conduit behind the radiator. It feels sturdy and I might take advantage of that to build a fan mount from later.
