performancelaw
I'm going to install a trans temp gauge. Where do I need to put it to get the best reading ?
Pan location is usually the best.
I tried putting it on the torque converter but kept running out of wire.
Where you can see it.
PAn temp on a slushbox is *essentially* an after the cooler temp combined slightly with the heat absorbed from the valve body being submerged in it and splash back from the clutch plates /gears but your major heat builder is the torque converter and the return fluid from there usually pumps straight to the cooler, but the return line basically dumps into the pan and then it waits there until it gets sucked up into the filter and gets sent on through the system through whichever way it gets used and then on to the cooler
A return line temp will tell the condition after cooling and before re entering and teh combination of it and a pan temp will tell the full overall operating temp. Teh temp entering teh cooler isn't so much important so long as you can bring it back under control, the problem lies when you can't get it back under control. You just don't want to be running your pan temps up near limits or you are asking for trouble
The average / constant temperature of the fluid in the pan - about to enter your trans - is what you should be concerned with the most.
