dsblack
So how does the heat get shut off when I move to cool mode. I can adjust the temp, but can never get cool air.
Thanks
Doug
Thanks
Doug
argve said:If the cable come loose from the cable clip on the air box it will do what you are describing... how do I know this... well because once I forgot to clip it in fully after I had been working in there.
If this is on your '90 there is the cable inside behind the glove box that is held in by a little clip as mentioned above, might be able to adjust this to close the door all the way in the summer then adjust it back for winter use.
Also under the hood under the hinge on top of the air plenum is a vacuum solenoid that operates a water valve, in max air this turns off the water. So if you run constant vacuum to it no water enters the heater core.
I warned ya'll about my memory.
I warned somebody about my memory, but I forget who.
