sticky lifter?
I've never used it, but I've heard alot about seafoam (sp?).
Mike
Stroker
Cora
I'm about to try a product from Lube Specialties (one of our sponsors) for this same issue on my 65 Mustang. 400 Protect-O-Lube is the juice and Chris gave me a specific procdure for product usage.
I'll let you know how it works.
hesutton
The Anti-Anderson
Bowling Green, KY
I guess my question is...........How would you know you have a bad/sticky lifter? Is there a certain noise or symptom that lets you know? Just trying to learn something new.;Sweet
Heath
Mike
Stroker
Cora
Hydraulic lifters have a distinct ticking sound when they are flat, sounds very similar to a leaking exhaust manifold.
sassyrel
iowa
genchow---you can also try 1 qt of kerosene in the engine crankcase--go out and drive it about 20 miles--have used this to get many noisy lifters quiet--but you have to drain the oil out when you get back----and try not to idle tooo much-----
Mr_Roboto
Elyria, near Cleveland Ohio
Use an oil detergent such as Rislone. Solvents will work quick, but they will break loose ALL the crud in the engine, not just the varnish in the lifter.
ntjapkes
