I pulled mine apart because my starter was hanging up. Then found my wiring harness to be on its last leg. As I started tearing that out I realized that if I was going that far I might as well rebuild it all with new bearings and paint. If you follow that link I posted a couple of messages up it will walk you through most of it. He uses a screw to get the tilt wheel pins out, but there is a tool for it that most jobbers have. The tool is probably less than 3 dollars.
The wiring harness for an '84 is non existent through Ford anymore. They can purchase it from an outfit who bought all Ford's old inventory for $140. I tried rebuilding my harness instead. We'll see how that goes.
It's a little intimidating at first, but it's not that bad.
Paul
Paul
