starter fluid
stevewillis
prunedale ca
how bad is it to give my truck a half seond shot b4 starting it..i was told my relay to the glow plug wasnt working. this is just a temp fix i know but am curious should i just stop driving it before i destroy something i do have another car to drive. i also have a block heater so if i plug that in will that keep it warm enough to start.it starts up fine once its been warmed up
dyoung14
Is getting worn out
spencer,tn
Make sure that the glow plugs are not heating before you use it or you will blow things up! I use ether to crank mine but i dont have glow plugs and i just shoot a little in it i dont think it hurts it at all i have used it in engines for years
jcarr
Tulsa OK
You also don't mind turning one 4 grand plus. :D
I crenge anytime I have to breakout the liquid sunshine.
stevewillis
prunedale ca
its 7.3 what does the controller look like im new to this i have a ats turbo on it is stuffed undrer there ?
bigugly93
southwick, ma
make absolutely sure they're not working by unplugging them. if you only give a SMALL shot you will not harm anything. the worst you will do, if the glow plugs are still going through a heat cycle, is expand the tips and be unable to remove the glow plug. any more than a SMALL shot and you are begging for fun stuff like holes in your pistons. used in moderation like designed there is nothing to worry about. but i do recommend fixing the problem. the block heater may not be enough to start without excessive cranking, if at all.
bigugly93
southwick, ma
sorry no pics. follow the injector lines to the heads look just below the injectors in the heads and its the ONLY wire there. there are eight of them. unplug them all and there you have it
do you hear the glow plug solenoid clicking at all?
your voltmeter should be twitching slightly when it does.
if you don't see any action whatsoever on a cold motor, you have no issues using the juice.
tjb
Aztec, NM
your best bet is to google 7.3 glow plug controller and it will give you pics and how to test it and what not.
stevewillis
prunedale ca
ya its clickin i think i better bring it up to ur shop to have u just give it a lookin over anyway towcat i got a couple other questions about it and your not that far from prunetucky
just give me some advance warning, I've been at home sick this week. I come in at night to get stuff set up for the following day so I don't pass on what I'm fighting to the rest of the crew.
jimmys f250
NIOBRARA, NEBRASKA
I do it everytime i start mine,,,have a maual controller so i dont push the button. i JUS PLUG IT IN FOR BOUT AN HOUR BEFORE I USE IT pop the hood give it a shot and vroom,, WORKS EVERTIME. WISH I COULD FABRICATE SOMETHING LIKE WHATS ON MY 856. THAT HAS A LIL CAN OF EITHER MOUNTED BY THE ENGINE THEN YOU JUS PUSH THE BUTTON AND IT GIVES IT A SHOT AND THE OLE GIRL FIRES
MadScientist
