I've got this problem with one of the studs on my left front wheel, it's so loose that I can spin it by hand and the nut won't come off.
Any idea on how to get it off and do replacement studs have a slightly larger shoulder area that enables it to stick in the now oversized hole...
Any help would be greatly appreciated...
PS, it's a Dana 60...
You have a problem that we at the tire-shop face almost every day.
What usually causes this is using an "air-gun" impact-wrench instead of proper hand tools; NEVER use an impact-wrench on lug-nuts except in dire circumstances.
About one time in five, the suggestion to remove all the other lugs and pry against the wheel while quickly spinning the nut off with the air-gun that caused the problem in the first place.
I doubt that a hand tool will be quick enough to spin the offending nut off; the slow torque will simply turn the whole works.
Most of the time, we have to use either a torch, cold-chisel, or cut-off wheel, depending on the particular situation.
Any of these methods will result in a highly damaged wheel, especially if it is an
aluminum
wheel.
The least damaging sure-fire way to set things aright is to remove the bearings and pull the hub, wheel and all, then cut the flanged head off of the stud.
I have even been able to drive the stud through the threads of the nut from the front side, depending on how bad the threads are stripped; the worse shape the threads are, the easier to knock the stud through; this operation must be done only when the whole mess is removed from the spindle.
