Wheel bearing tightness?
You can grind it, but I have found if I have room, the quickest way for me is to center punch the center of the rivet head, and then take a drill and drill the head out till you get to the depth of the frame. Once the drill bit has hogged out the center of the rivet head, a couple of wacks with a large chisel will break the rivet head off. Then just drive it out of the frame.
I like to use a grinder to cut a groove across the middle of the rivet head almost all the way through. Next I use a chisel end on my air hammer to easily knock the head off of the rivet. After that, I just use a punch end on the air hammer to drive out the rest of the rivet.
papadiesel
Indianola, IA
On four-wheel-drive torque to 70 pounds spin a couple of times back off a quarter turn torque to 22 pounds, This is 44 and 50 HD TTB with ratchet style locking nuts
jrollf
Houston, TX
I didn't have to take the radius arm bracket off to replace the bushings on my 93 F350. When I had the axle pivot and sway bar disconnected, with little effort I was able to get the trailing radius arm out of the bracket.
I think the key was I had everything (except the coil spring) disconected as I replaced all front end bushings at the same time, including the sway bar and pivot bushings.
Daniel McCurdy
Evarts KY
Well, while I was under there today I checked every rivet, bolt, and mount and everything was tight. I did find one thing that might be loose, the lower spring mount, the big washer I could just jiggle around and was very loose. I'm guessing it's supposed to be right and not loose
That means bolt 388727 is loose? That holds the radius arm to the front axle. That's not good that it's loose.
Daniel McCurdy
Evarts KY
oh wow i didnt realise it was such an important bolt crazy thing is both sides are loose. i should probably try to tighten those up
