Send it in for a core, or Sell it?
82fordtruck
NE Kansas
No, I think Believer45 missed something.
This was a double post - an identical one was made over at TDS. the moderator over there didn't like it, so he locked it.
tractorman86
Buckeye, AZ
yea i figured they inflated the #'s a bit but i know the ATS kit works absolute wonders with the right gears, pump settings and the right mechanic doing the instal! (my old man hads a 92 at/w ats, 4" exh, pump turned up and 3.73's; lets just say if dad knew how fast i had that truck back in highschool i wouldnt be here today!! guessing 140!!!! :rotflmao :D) as for the stock setup i knew it was about pathetic we bolted one on a 90 service truck of ours and u cant really tell any difference!!! oh by the way diesel jd, a 5' tire bar fixed the clearence issue! :D :D
argve
Resident Fruitcake
Gwynneville, Indiana
How could you get one so fast - the gear ratio was the biggest hold back on the E - 4:10 gears and I made Mel (agnem) give his classic groan when he looked over at the dash and seen where the RPM needle was pointing... Even with 3.55 gears I would venture maybe 105 at best...
hey goat-
I have a official Texas "warning" stating I was running 104 via radar :eek:
4.10's in the back, ZF5 in the middle. 3200 on the tach. Speedo was way pinned. I slowed down to 85 after that "warning"
Dave85 can also swear my f450 will run 85+ with 4.56's in the rear. tach is bouncing off the governor at 3600. He didn't think I was going to make it from SJ to Manteca just a little over an hour. I proved him wrong :rotflmao
82fordtruck
NE Kansas
what tires on the f450? mine hits the governor at 3300.
now you've really got me thinking.
I've had the governors on my pumps reset higher. highest you want to go is 3800. I had them set at 3600. tire sizes on both the f350 and f450 are 235/85r16. The f350 was the 104mph runner. There was still some throttle left too :eek: The TxDPS guy was really curious what I did to the truck and spent darn near a half hour talking and looking under the hood. I know he lurks on this site. ;Sweet
82fordtruck
NE Kansas
Maybe I need to check the gear ratio sometime. Maybe it has something else in it. That would explain why I can start off in second gear with a decent load.
I have 215/85R16 tires. Will that make that much of a difference?
215's are a little smaller but not make as much of a difference you are reporting. here's a snapshot from this afternoon. look at the mph and the tach. I could have went faster but there was a ton of traffic around me today.
82fordtruck said:
mine's there at around 77.
65 is over 2500
55 is over 2000
Somehow I have a feeling you have 4.56's in the back or 5.13's....if it takes you little to no effort to get rolling and top out that soon, I really doubt you are at 4.10....but then again, I may have been geared down too. who knows...
tractorman86
Buckeye, AZ
yea i think i was at 3500 with an E4OD :puke: i also think she had 285-75-16's on her (not too smart to put that much power to that tranny i know from experience if u know wat i am sayin!, but it was a blast) i was guessing at the 140 because it took the spedo 8 SECONDS TO COME BACK OFF THE PEG!!!!!! :rotflmao towcat and napa, i'd say 4.88 or 5.13 (with the gears he has it would make quite a big difference i gor a ticket for 92 in a 65 -cuss in another truck and the spedo was saying 80), i'd bet u could pull one hell of a load but that truck is still faster :D :kick:
Freight_Train
Traitor to the brotherhood
Gadsden,Al
The fastest you can go period at stock governor with an E4OD and 4.10 gears is 105,bump the governor up to 3600RPM you can get up to 114 but considering I could rev the Enterprise up to 4000RPM in neutral(*** did you do Travis?!?!?!?!) she can do 127.With 373 gears and stock Gov you can turn 115MPH.But with 3.55 in OD with a gear vendor and bumped up Governor(3600) 170MPH(Muh Ha ha ha).
