Scout down, NOT GOOD!
Dieselcrawler
Professional wrench holder
Quakertown Pa
i snapped the tailshaft and rear housing off the back of my t19. still have all the parts. 1500 rpm clutch drop with parking brake on - bad day. but made me feel good for some reason.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Thanks guys.I wasn't aware there was a diesel 6.32:1 trans, thought it was just the 5.5:1. I'll get the scout to the garage mabe tonight and tear into it and then ill start contacting the generous members offering me parts. Its like a big happy family here! Lol.;Sweet
-Jon
hesutton
The Anti-Anderson
Bowling Green, KY
Jon, that really stinks. Hope to hear what the carnage reports brings. Gotta wonder why the good 'ol T19 let loose.
Heath
That's a darn shame. Sounds like you had a tooth cut loose on you or something. There is loose metal in there somewhere.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
this is the only visible damage with the top off, i pulled the truck up with the top off and the rest of the gears looked good. :dunno
-Jon
6.9poweredscout
Bleeds IH red...
Northeastern Pa
i pulled the top off it tonight and let off the clutch in "neutral", it moved, i could only move the front ring with my hand, either front or back the trans locked, same with the reverser arm, front or back it locked. :dunno
-Jon
crashnzuk
West Sacramento CA
-Jon
There isn't, it's just a gas version wide ratio t-18. There are two t-18s, one with 6.32, and one with 4.56(?). The t-18 is a near bolt-in replacement for the t-19.
Travis..
Dieselcrawler
Quakertown Pa
the np435 will also bolt in. only thing i had to change was the revers plug on the harness.
crashnzuk
West Sacramento CA
There are a couple of different bolt pattern t-18s. One from a Ford gasser will bolt up. IH was/is known to have some really oddball stuff.
Travis..
plywood
Recovered N/A
Portland Oregon
out of? whats the first gear ratio???
zuk, most t18s i've seen (mostly in scouts) have the trans to bellhousing bolts IN the bellhousing?
-Jon
I think the ratios are all on gearvendors site.
But the NP435 is coveted for having the lowest first gear.
You need a bellhousing off of a T-19 IDI Diesel and bolt that to the NP435 and that's supposed to work.
