Franshisca, I can guarantee that your truck does NOT have king pins. It has ball joints.
Really now, and when was the last time you saw a crew-cab 4x4 '90 1-ton GM truck? Cause, ya know, those had the older body style and suspension setup till '91... Just sayin'
Also, +1 on the steering damper being a bandaid - I've driven some SFA trucks that didn't have one and even with big tires there was no death wobble. Things to check and replace if questionable:
- shocks
- steering linkages
- leaf spring and shackle bushings
- swaybar links and bushings (if applicable)
- frame around steering box, known for cracking on GM trucks
Franshisca has the first two taken care of already, so next up would be spring bushings and frame rail around steering box. Loud pop with new steering linkages suggest the issue is not the linkages, but either the axle (put your hand around each kingpin while dad is turning the wheel with engine OFF and see if you can feel something shift), the spring bushings, or the steering box and/or frame rail where it mounts.
To rlb245: IDI Fords do not use idler arms, neither for the 2wd or any of the 4x4 axle setups. Pitman arms are a non-wear item in all cases, replacing one is just a waste of money and effort. On a 2wd what wears regularly are the I-beam and radius arms bushings, the tie rods, and the balljoints. And swaybar bushings if so equipped (some are, some are not). The bushings can and will cause the front end to wander in some cases all over the road, not sure about wobble tho. Steering damper is nice to have but not needed, my 2wd dually never had one from the factory and it drove just fine, the only reason I gave it one was gravel roads driving me nuts cause of all the vibrations at the steering wheel they cause. Whether the alignment shop will tell you if alignment is all messed up depends on the shop, if they put it up on the lasers and took measurements they will know the current camber and caster angles and can tell you if they are within specs or not - worn/loose tie rods and linkages do not affect those angles, just the toe, which in your case is somewhat irrelevant. You did say you replaced ball joints, camber/caster adjustment on both 2wd and non-kingpin 4x4 Fords is done thru the upper ball joint by rotating the off-center sleeve it passes thru, so it's very very easy to mess up the alignment while replacing ball joints. I'd say get the steering linkages replaces ASAP then go back in for alignment, actually do the I-beam and radius arms bushings too before the shop visit cause they can affect alignment as well and it's somewhat of a waste of money to have the shop do the alignment work twice.
