rockers and lifters
fuelscrew
Diesel Addict
Chambersburg PA
OK so has anyone that built one of these engines used the roller lifters from redline on eBay I'm planning a build and was thinking about trying them out. Also will a BB ford roller rocker fit these heads or are there ones available for the 7.3? Thanks in advance
Well... Without seeing or reading a part number on the redline lifters most all I can say is I don't know. Please.... You have to give us more information that this if your expecting an educated answer...:rolleyes:
racer30
western Oregon
I have been thinking the same thing about the rockers. I just havent had a big block roller rocker to play with to see if it could be adapted to work. the offset is the problem I see and needing some sort of push rod guide plate and hardened push rods the correct size. and custom taller valve covers might be needed.:dunno
rjjp
Needs to go test
Clare, Mi
Custom valve covers seems easy enough. Hmmm, I may need to tear a big block apart, to bad the owner of the local scrap yard is saving the 460s.
Funny how hypermax only shows enough rockers for a v or straight six engine. Anybody else see just 12 rockers....:rolleyes::dunno
hesutton
The Anti-Anderson
Bowling Green, KY
Those rockers are for the 300 and 400 series IH DT's. Not IDI's or PSD's. That's why you only see 12, they are intended for an inline six cylinder (DT360 or DT466). No...... they can't be used on an IDI.......we don't have a rocker shaft in our heads.:D
Heath
fuelscrew
Diesel Addict
Chambersburg PA
I have found new lifters and valves on eBay from a place called redline they claim to be a supplier for engine rebuilders everywhere the y also carry pistons up to. 40 over and full gasket sets with bearings and rings feedback is good but the prices just don't jive they seem way low but I may try them out who knows maybe they are decent. If I do go this route there will be a full write up as well as the machine shop I'm gonna use
The liters used in the idi is the same as the 6.2 and 6.5 chevy diesel engine. Also the same as the psd engines. They are kind of a generaic liter used by many differant engines. Mose than I posted here. The only rockers available today are the newer.better 7.3 rocker. The older 6.9 rocker had an aluminum fulcrum in them. That didn't wear too well. They are the rockers with the bridge between the intake and exhaust valves. Usually ebay has lifters listed all the time. Figure $160.00 for a set but.. You can find them for as low as $90.00 per set...:sly I think typ4 (Russ) rebuilds them too so might give him a call.
fuelscrew
Diesel Addict
Chambersburg PA
hesutton
The Anti-Anderson
Bowling Green, KY
You might want to look and make sure the exhaust valves are inconel or have a stellite face. Those are less likely to be a problem down the road, especially if you are going to turbo your truck. I see you have NOS on there per your sig. And, boring a 7.3 is a risky proposition, I hope you don't need 40 over pistons. If so...... sleeve the block rather than bore it.
Heath
