Optikalillushun
After my last tirad i sought out to repair my leaking return line caps. Same ol song n dance, got everything back together and today i was using it and got home to check for leaks and the whole passenger bank is wet with second from the front oozin fuel. I have HAD IT, i dont know what else to do. This is now three different return line kits (two sourced from Typ4 which were good with no burrs inside) and half a dozen different sets of viton orings. Im at a loss here, its really ******* me off having to crank it for 5-8 seconds to get it to fire up cold. Thankfully everything else is in good working order (GPs, GP controller, batteries, starter, wiring). Also the rough idle on a warm start gets old, a quick blip of the throttle clears it up but gets old especially when someone else uses it and they have no idea what to do.
Could it be a burr or irregularity on the injector themselves? I dont see how after properly installing the orings (6 times) and 3 different sets of caps its all on me and my install. I make sure the o-rings are nice and lubed up and gently roll the top one into place and then roll the bottom on in to avoid tearing the bottom one going over the open top slot. Everything seems tight when its all together...
Think i should pull the injectors and check them for burrs or whatever? i dont know what else to do...When its been warmer here (above freezing) it doesnt take all that much to start it even after sitting but still longer than normal.
