Rear axle seals and bearings
fraree
Inland. Australia
Now the work begins in ernest. Finished up (pulled the pin) from my employer Friday, now the preparations for our extended road trip around Australia.
Started on the a/c system. Being a retired ambulance it has a separate "under dash" type system mounted in the rear. The rear system has always worked 90% better than the front. Cleaning the externals first but I wonder if a rebuild of the whole system would be worthwhile ie compressor, receiver drier etc should sort it out. Heating is not a requirement in Australia so I removed the heater core. Why would anyone make cool air have to push through a heater core before it enters the passenger area ?
fraree
Inland. Australia
Well the left rear wheel bearing is done, a few weeks back. Had to buy the socket to tighten the spindle nut along with borrowing a reverse tension wrench.
Cv axle
