Just to update my thread I got the job done and my truck passed inspection! Replacing the axle bearings and seal is not a huge job but it did take me some time...it took me longer just to put new brakes on the truck. It was hard for me to get the "meat hook" looking things hooked up to the spring that holds the shoe down.
Another note is that my truck is a single rear wheel truck and it takes the 3" pads not the 2.5"
In the kit I purchased no rtv was used, the big bearing that was replaced is supposed the be packed with grease, and the smaller outer bearing that is reused you just lubricate that with gear lube. Please let me know if you have any questions while everything is still fresh in my head
the nasty ness
here is the kit that I got from napa
old stuff out
new bearing with grease
oil slinger on top, fins pointing towards the bearing
seal installed, and yes they just push in
here are both hubs, with the repair/upgrade kits installed
buy twice as much brake cleaner as you think you might need. It's great stuff, but I needed probably 4 cans of it. Cleaned up with new hardware and new shoes.
My phone battery died, so those are the pictures I have. I did both sides but all of those pictures are from the right rear
