there are charts out there that you can see clamp load vs torque for X fastener,
I dont know what exact material or grade the arp stuff is, but I bet it is higher than grade 8,
but for example a fine thread gr8 .5" fastener, installed with lube at 80 lbs will net 14400 lbs of clamp load
we have 5 bolts per cyl, so clamp load is approx 72000 lbs per cyl using our gr8 fastener for ref.
just ball park, but peak combustioon pressure in a HI-PO diesel is 2400 PSI, we have a 4" bore, which is 12.56 in^2
so 12.56*2400=30,000 psi per cyl
So we have a FOX of over 2x with this fastener.
So yes, you are most likely ok with 127 ft lbs.
You did install with ARP lube right?
If you did it dry 127 ft lbs, that is equivalent to like 80 ft lbs lubed.
the hysteris skew gets even higher the more torque you induce un lubed.
