wanted ot go for a longer test ride with my buddy yesterday, goit out of the shop, but moved it bakc in, then try to go out-the brakes are locked up. checked everything in the HB system. turns out all 4 calipers locked up. Took the rear ones off, one side had both pistons cracked, other the seals were ,mangled. i don tknow how this hapopened, but stuck pistons are apparantly common on super duties...
well, 260 bucks gone tomorrow for all 4 calipers, but at least theyre new. They have phenolic pistons instead of some kind of cast alloy these ones have.
also i really gotta get the shifter mounted on the Tcase, im still in 4 low, and i cant get past neutral. I know on the bench I got it into 4hi so its not stuck, BUT i never was able to get it into 2hi (the last position out). Im sure its just crudded up in there or something, some driving around to get lube all around should help the shifting. Im just getting under the truck and using a crowbar to shift it right now.
