Questions about / need a gear driven PS pump...
dieselcruiserhead
Before I had the engine in, I needed to run it to make sure it works/etc. I didn't have the PS/hydroboost lines hooked up and have killed my pump. It is a gear driven one that bolts in before the fuel pump on the driver's side. This is also a 1991 4BT but a pump from a 6BT should work. Any ideas on where to get one/find one? Anyone have one used? Ideas? Need it ASAP and cheap :( Considering a rear main seal was $75, scared to think of what it'll be for this!
CRobey
If the pump is the old gas style, get a pump for a Chevy small-block and bolt it to the adapter.
If it is round with a remote resivoir I will get you a part number from Freightliner.
Let me know if this helps.
Chuck
Ggg
Northern IL.
When I got my truck the PS pump was missing. I found one on e-bay for about $60, granted it did need a seal kit but still a lot cheaper then the parts store.
