Mike, I hope there is no additional damage and that you can still make it to the rally if you want. You certainly deserve a break at this point. When I was torquing down the rocker arm bolts after I re-installed the heads last summer, I was on the last bolt on No. 1 and heard and felt a "crick"! Sure enough, the bolt broke and I was not even to torque yet. When I looked at the bolt, you could see it had a stress crack and torquing it down snapped it the rest of the way. So I pulled out the broken stub and torqued in a new bolt. So, after that experience, did I go back through and remove each and every rocker bolt again after I had them torqued down? Nope, ran it and everything has been fine. I guess crap can just happen, even though the odds of it happening are small. In my case though, I tightened the bolts down to torque spec., and had no issues with the others, so I had at least some confidence that the rest of the bolts were okay. By the way, if you need a genuine new Ford OEM rocker arm bolt, I have a couple in my spare parts inventory.
