Pre Rally get ready thread
91idi
Fiberglass *****
X
My 86 is now a driving truck! Now all 3 girls are ready for action!
Dsl_Dog_Treat
Decatur,MI
What happened ron
IC is heat soaking the radiator. Hit 225 today bob tailing Goldie in 90 degree heat. Not doing another memorial day trip watching the water temp gauge.
I really need to know what Heath is dealing with tho.
92F350CC
Ford Man
Las Vegas
What IC did you have on Goldie? Perhaps your cooling system is in need of a refresh.
Dsl_Dog_Treat
Decatur,MI
I'm running one off a 99 powerstroke with 3" plumbing.
The cooling system has roughly 70k on it.
Radiator is showing the start of solder bloom so it's the weak link right now.
I had to concede to defeat this round. Will more than likely leave that setup for my plow truck. A turbocharged IC equipped 3/4 ton regular cab truck should really make an interesting combo. :D
smokinpipes
Navistar Nut
Kalamazoo Michigan
Got the old girl washed, and I wish I had time to give her a wax job; but alas I do not.
Replaced the front driving lamps to "hide" the deer damage; checked the fuel, filled the oil...
Next up: load up!
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
Took the front bearings apart for a re greasing and bent the cage on the right inner bearing.-cuss Lucky I have a great sister stepping up and delivering parts support.:angel: Aired the rear bags to 50psi, electricals check, fluids, down 1 quart engine oil in 3500 miles, with a known leak, will do oil change after the rally. Wrapping up tools and leaving to get the kids this afternoon. Hooking up trailer and jetting by 5:30 ish Eastern time. I am so ready!!:D
Dieselcrawler
Professional wrench holder
Quakertown Pa
me and mathiass will be cruising slowly john, seeing if yall catch up. i spoke with jason last night about it.
