Alignment shop + twin I beam = bad things
Last time I took my F150 in for alignment, they put 1/4" of toe in on the front end. Right then I decieded to never take any of my vehicles in ever again. Maybe you had better experiences, but the shops here haven't earned my trust.
Steering column is nice and loose and I can swing the steering shaft from under the hood of the truck without any drag felt from inside the firewall. I can disconnect the steering shaft from the steering box and basically spin the wheel freely. Nothing drags, and tilting never affected anything. No slack in the column either.
There is no steering dampener on the truck.
I heard about changing the caster with an aftermarket radius arm bushing but I have to think that these trucks didn't drive this way from factory. My understanding is that these trucks are still designed with manual steering in mind and as such have very little caster angle to reduce effort when manouvering without power boost. Its rare, but some trucks in this era didn't have power steering. Probably doesn't take much stiffness to cause this condition.
Quite frustrating though, because with the truck on blocks, the wheels are quite easy to turn by pushing against the tires. Maybe I'll try making movements with the truck in the air with one side disconnected to see if I feel any difference or added drag. Not much work this week, so I might have time tomorrow to dig a little deeper. I'll check to see if the tie rods are bent at all.
Something I should add is this truck was used for towing a 5th wheel travel trailer by the PO (all over the continent actually). Is it possible that he had the front end changed to account for the added weight of the trailer? The truck does seem to track better when there is a heavier load in the back.
